so if i pick a resistor like you said 66 ohm but 68 would be fine . i would want to go with a higher value i assume? great posting btw!
Yellow wires are +12v.on the atx power supply. what color wires will i use for the 12v and for the 5v? i have the red,black and yellow plus one white orange and blue. is there a load sense?
Would be nice to see a circuit at this point.so ive managed to get my psu supply to work but its only giving out 11.35 volts. how is that going to change the number of leds in the series? value of the resistors?
You are probably not getting good regulation on 12v because there is little or no load on 5v. ATX form factor supplies require a couple of amperes load before they'll regulate the other voltages halfway decently.so ive managed to get my psu supply to work but its only giving out 11.35 volts. how is that going to change the number of leds in the series? value of the resistors?
by Jake Hertz
by Aaron Carman
by Aaron Carman
by Jake Hertz
