Correct - as long as you can read the digits on the switch you're set. You can always go elaborate later once you've gotten your feet wet with electronics.It is my understanding that with these switches I would not need another display.
Both - they're interlaced. You'll probably want an mcd rating of 2000 or more so you can better see the display in daylight. Viewing angle will determine how easy it is to see when not directly in front of the display. Viewing angle is a little tricky because it doesn't mean the display isn't viewable outside the given angle, it just drops off considerably. It's easy to find large mcd-rated LEDs, but these often have a small viewing angle making them almost like lasers - lots of light in a pointed direction but hard to see if you're off to the side - of course you wouldn't look into a laser, but that aside . . .What is more important, viewing angle, or mcd??
Again, I think you'll be good with 30-45 degrees and 2000-8000mcd. Don't worry about 360 degrees or +10k mcd. I think I've got some blue (maybe others too) LEDs from LEDshoppe at home. I can take some pictures from different angles and distances if you'd like to give you an idea. How far away does the display need to be seen from?
I buy colored transparent acrylic from Tap Plastics: http://www.tapplastics.com/product/...plastic/acrylic_sheets_transparent_colors/519What do you use as a filter??
I just noticed they carry PVC too: http://www.tapplastics.com/product/plastics/cut_to_size_plastic/foamed_pvc_sheets/342.
They've got good prices and cut to size without an additional charge. Once you've determined your size, play with the quantities - often it doesn't cost much if any more if you increase your quantities to some point. For instance, I just priced 1, 2, 3, 4, and 5 sheets of gray PVC at 12" x 12" x 0.125". I can pay $10 for 1, 2, 3, or 4 sheets total. Goes up a little for 5 sheets. I'm not sure how their system works, but I guess they have some minimum that works in your favor for ordering more. Now instead of paying $5+ per sheet from McMaster or Enco, you can pay a cool $2.50 by ordering 4.
