Yeah, do that. I'd be interested in what happens.it might not work at all ... but I'm sure as hell gonna test it ...
PR2 Timer2 is also used for the period register when using PWM.Timer2, on the other hand, also uses an 8 bit counter, but its reset value can be adjusted through a register named PR2.
My theory is that two timers were made available for this chip, and Picmicro appear to try and keep thing standard across different versions as much as possible, and a PWM module is present so the usual PR2/TMR2 was included because of this.Ok, this chip has two timers: Timer0 and Timer2 (what happened to Timer1? ).
I know what an XOR does ... but would you mind being more specific? I'm suffering from complete mental block right now ...Try xor'ing it. That is , 0x01 xor 0x01 = 0, xor w/ 0x01 = 1 ...
Very often used to flash LED's or switch anything alternating with a delay in between.
You will use xorlw or worwf depending on your code.
Of course xor w/ 0x01 only affects bit zero.
John
why "xorwf LATA, f" instead of "xorwf LATA, 1" ? is it the same thing in PIC syntax?Saves a step:
Code:movlw 0x01 xorwf LATA,f ;pulses LED (i.e., LATA, 1)
; 11 JUL 2018, 12:39:15 PM:
; Generator controller for the PIC10LF322
; The following program flashes a LED connected at RA1 for 0.1s once per second using
; the Timer interrupt feature. Internal oscillator is set at 31 KHz
list p=PIC10LF322 ;list directive to define processor
#include p10lf322.inc ;processor specific variable definitions
radix dec
; - Flash memory self-write protection off (default state)
; - Brown-out reset low trip point is selected (default state)
; - Low-power Brown-out Reset is enabled (default state)
; - High Voltage on MCLR pin must be used for programming
; - Program memory code protection disabled (default state)
; - MCLR pin set as digital input
; - Power-up Timer disabled (default state)
; - Watchdog timer disabled
; - Brown-out reset is enabled (default state)
; - Internal oscillator is activated
__CONFIG _LVP_OFF & _MCLRE_OFF & _WDTE_OFF & _FOSC_INTOSC
; in this architecture, general purpose registers are located in addresses 40H through 7FH
TEMPVAR EQU 40H ;TEMPVAR creates a direct reference to memory location 40H
; Reset and Interrupt program memory locations
RESET_VECTOR: ORG 0x000 ;processor reset vector
goto Init ;go to beginning of program
INT_VECTOR: ORG 0x004 ;interrupt vector location
;clear the Timer2 to PR2 match interrupt flag
bcf PIR1, TMR2IF
;complement RA1's state, effectively turning on the LED for 1 second
;and off for another second
movlw b'00000010' ;load W with a filter
xorwf LATA, 1 ;perform an exclusive or on the contents of W, filtering
;bit1 (LATA1) ... if LATA1 was zero, it will be set as
;one, if LATA1 was one, it will be set as zero ... all of
;the other bits will remain unafected
retfie ;return from interrupt
; Main program start
Init:
;the reference Clock output bit CLKROE is disabled by default, we'll leave it that way
;set the internal oscillator frequency to 31 KHz (the lowest possible), this is done
;by clearing the IRCF bits, which belong in bit locations 4, 5 and 6, respecively
movlw b'10001111' ;the W register has been loaded with the IRCF bits as zeroes
andwf OSCCON, f ;AND the W register with OSCCON, storing the result in OSCCON
clrf INTCON ;make sure that all interrupts are disabled for now
;************************************* I/O definitions ***********************************
CLRF ANSELA ;clear the analog select register, which for some stupid reason
;is enabled by default ... otherwise the digital i/o function
;won't work
;BANKSEL PORTA ;this instruction is not necessary with the 10LF322, since it only
;has one bank of SFRs
;set all pin outputs as zeroes (low), to prevent the LED from starting up already
;lit before enabling the timer interrupt function
movlw b'00000000'
movwf LATA
; - set RA1 as an output, active high ... leave RA0 and RA2 as inputs ... RA3 can
; ONLY be an input
;10 JUL 2018, 5:57:17 PM: By the advice of JohnInTx a complete movwf to TRISA should
;be used, instead of writing to the individual TRISAX bits
movlw b'00001101'
movwf TRISA
;Interrupt period is given by: PR2 * T2CKPS * TOUTPS / (Fosc/4)
;to get a period of one second, the following values make for the best approximation:
;Remember that the clock input for the timers is Fosc/4, in this case 31 KHz/4 = 7.75 KHz
;PR2 = 8D <- Timer2 compare and interrupt trigger value
;T2CKPS = 64D <- prescaling factor, 1:1 to 1:64
;TOUTPS = 15D <- postscaling factor, 1:1 to 1:16
movlw d'8'
movwf PR2
;check the structure of T2CON to understand the following instruction
movlw b'01110011'
movwf T2CON
;enable Timer2 to match PR2 interrupt
bsf PIE1, TMR2IE
;enable all active peripheral interrupts
bsf INTCON, PEIE
;enable all active interrupts
bsf INTCON, GIE
;turn Timer2 On
bsf T2CON, TMR2ON
ProgramLoop:
goto $
END
; Saves W common area or replicated banked RAM as necessary
; Saves status and PCLATH in banked context save RAM
; Polls sources and goes to routine
; IRQ routines come back to IRQreturn
movwf IRQsaveW ; save W reg, in common area if available
; iff not available, replicate IRQsaveW in each bank
; for banked systems
swapf STATUS,W ; get status reg without changing flags
banksel IRQsaveS ; save it in context bank
movwf IRQsaveS
; Saving PCLATH is necessary only when multiple ROM banks are used
movf PCLATH,W ; save upper address as req'd
movwf IRQsavePCLATH
; set PCLATH to point to service routines
pagesel svcTMR2 ; better way to do it
; Check flags and exit iff none set, else, do em again
; without running foreground (just burns overhead)
btfss PIE1,TMR2IE ; Timer 2 irq enabled?
goto chkNext ; nope (can omit iff you never turn TMR2 off)
btfsc PIR1,TMR2IF ; Timer 2 needs service?
goto svcTMR2 ; Jump instead of call to save stack space
; Check other IRQ sources as required
chkNext:
; Service routines jump back here
IRQreturn:
banksel IRQsaveS ; locate saved context
movf IRQ_PCLATH,W ; restore upper address (iff used)
movwf PCLATH ; NO more calls or gotos after this..
swapf IRQsaveS,W ; get saved status
movwf STATUS ; now.. we are in the original banks
swapf IRQsaveW,F ; get saved W without changing flags
swapf IRQsaveW,W
retfie ; return and reenable
I guess I'm too spoiled by the PUSH and POP instructions available in the 8051 ... how is IRQsaveS supposed to be declared?Typical midrange context save code:
EDIT: used pagesel directive for PCLATHCode:; Saves W common area or replicated banked RAM as necessary ; Saves status and PCLATH in banked context save RAM ; Polls sources and goes to routine ; IRQ routines come back to IRQreturn movwf IRQsaveW ; save W reg, in common area if available ; iff not available, replicate IRQsaveW in each bank ; for banked systems swapf STATUS,W ; get status reg without changing flags banksel IRQsaveS ; save it in context bank movwf IRQsaveS ; Saving PCLATH is necessary only when multiple ROM banks are used movf PCLATH,W ; save upper address as req'd movwf IRQsavePCLATH ; set PCLATH to point to service routines pagesel svcTMR2 ; better way to do it ;****************************************************** ; Check flags and exit iff none set, else, do em again ; without running foreground (just burns overhead) btfss PIE1,TMR2IE ; Timer 2 irq enabled? goto chkNext ; nope (can omit iff you never turn TMR2 off) btfsc PIR1,TMR2IF ; Timer 2 needs service? goto svcTMR2 ; Jump instead of call to save stack space ;************************ ; Check other IRQ sources as required chkNext: ;********************************* ; Service routines jump back here IRQreturn: banksel IRQsaveS ; locate saved context movf IRQ_PCLATH,W ; restore upper address (iff used) movwf PCLATH ; NO more calls or gotos after this.. swapf IRQsaveS,W ; get saved status movwf STATUS ; now.. we are in the original banks swapf IRQsaveW,F ; get saved W without changing flags swapf IRQsaveW,W retfie ; return and reenable
by Jake Hertz
by Duane Benson
by Jake Hertz
by Jake Hertz
