I am talking of the clear plastic sheet with traces.
I dropped the keyboard into the sea. Transferring from dock to boat, I dropped it into the water, of course it did not work anymore.
I took it apart, rinsed and dried it, but 2 groups of 4 keys did not work.
Looking at the trace and measuring ohms, I found a bad discolored spot with no continuity.
Suggested fixes were rub a pencil over it, that sounded promising but did not work.
So I used a piece of tinned wire out of a PC power supply wire, stipped off the insulation, used a tiny thin strand, cut about an inch long, placed it on a piece of clear tape, and taped it onto the damaged circuit trace.
It worked!
So did plugging it in after it sat in the sun and was still wet inside cause that trace to go open? The damage was about a length of 1/4 inch of discolored trace.
It worked!
