Joule Thief Circuit
linxdev
Joined Jan 24, 2011
3
I've built this circuit and have a question.
http://www.jtkit.com/Schematic.html
At Vout I read 29v. I put a load of just one small 3mm red LED. It blinks for a second then the voltage on Vout drops dramatically to less than 1v. What I'm trying to do is build a dirt battery that can use this circuit to power a LED for my daughter's science fair project. Currently I'm testing with 1 1.5v AA.
Is there a possible component failure?
Also, I would like to simulate this in Multi-Sim but can't find the component for the iron core inductor. Is it possible to create it?
Thanks,
Chris
t_n_k
Joined Mar 6, 2009
5,455
Does the circuit work in regulated mode? i.e. with the jumper switch connected.
Are you including a series resistor with the LED when connecting as a load?
t_n_k
Joined Mar 6, 2009
5,455
A series limiting resistor is a good idea. Try 100Ω 0.25W as a start.
The voltage is probably dropping out because the load current is too high with the unlimited LED. If 100 ohm doesn't work try something higher - 220 ohm etc.
linxdev
Joined Jan 24, 2011
3
Thanks. I had a 150. I think the LED was failing. I pulled another one and it works great.
At 150 the voltage is 3.75v
Chris
