My bad. I failed to spot the U7 connection.I don't see any floating inputs.
Thank you joe for the info.Nathan,
Is that 74HC78_2V a two volt model? Make sure your initial conditions are proper at energizing. You measure the Highs where there should be highs and lows where you should have lows.The wiring appears correct, although your drawing could have been cleaner. Attached is my drawing ... the 74HC21 and 74HC78 are macros vice individual gates. The red dots are highs upon energizing the circuit. I know the reset is HIGH even though it does not have a red dot.
