No.It is ok and reliable to use 5v relay with arduino due 3.3v without logic level shifter ?
A 5V relay would probably pull in at 3.3V, but I don't know of any relays that will work at the level of current an arduino could supply. Use a transistor to drive the relay as @dendad said.It is ok and reliable to use 5v relay with arduino due 3.3v without logic level shifter ?, what do you think ?
Is using logic level shifter is more reliable ?, yes... relay will triggered with 3.3v even 2.8v but it's labeled for 5v useA 5V relay would probably pull in at 3.3V, but I don't know of any relays that will work at the level of current an arduino could supply. Use a transistor to drive the relay as @dendad said.
And don't forget the diode across the coil.
If you know the voltage is OK, that’s half of it. The current is the other half. Can the Arduino deal with the current the relay demands?Is using logic level shifter is more reliable ?, yes... relay will triggered with 3.3v even 2.8v but it's labeled for 5v use
