I'm trying to select a delay timer for a twin fluroscent light in the garage and I really like this one because it has a manual override to allow light to stay on indefinitely when required...
http://www.pdlglobal.com/data/product_documents/648TM InstallSheet.pdf
When looking at the wiring it looks like it has three wires but on the garage light switch it has only 2 wires - red and white ... which looks like one goes to load and the other to neutral (can someone confirm if that is correct?)
With the Active wiring not wired... would it still work? especially the indicator light on the front of the timer switch? Just trying to understand what I am buying and if it will work with what I have (Australian Wiring)?
Oh the red and white wire on the HPM 1 gang switch is wired to the common with white wire and terminal 1 with the red wire.
Any help would be greatly appreciated.
