Yup. Now you know why you see so many 'I wouldn't use a 741 if I were you' posts in the forumsWow, that was a hard lesson to learn
Did you check that out?I know that the NE5534 was recommended earlier in this thread
The radioshack website says they sell a LM324 and the inputs on that can can go from 0V to 1.7V less than the supply voltage.
Check the opamps listed by your intended vendor. If you can, do a parametric search looking for those needing a single supply voltage which can be as low as 5V, with rail-to-rail input and output. The sensor draws only ~1mA so that shouldn't be a limitation on choice.
Looks fine. The Vicm figures mean the input (inverting or non-inverting) can go right to ground or V+ (in fact 0.2V below ground or above V+). Since you will be using this as a unity-gain voltage-follower the non-inverting input will always track the inverting input, so the difference between the two inputs is always less than the maximum allowed 1V (as per the datasheet). You will need to ground the inv and non-inv inputs of the unused second opamp in the package.What do you think of this?
.... but the '324 output isn't rail-to-rail, so can't get much below ~1V.
Edit:
