I want to make a vibration sensing device that can be accessed via smartphone remotely, can anyone help me connect ESP 32 webserver to ADXL 345 ?
It does not include any reference to my problem, but thankshi Arijeet.
This may help.
E
https://www.youtube.com/results?search_query=ESP+32+webserver+to+ADXL+345
Yes , i already went through the video that ericgibbs referred to , and i tried to work on the problem , but could not get into a solution , the problem was that i was not able to create a sensor object for ADXL 345 it always displayed error like " the object does not belong to any type". It made me wonder if ADXL 345 is the right sensor to create a webserver or not . I am novice in this matter, and only trying to work on my academic project. And yes if there IS any working code for my problem, please do let me know . Thanks !Your not trying to fix your problem.
Think about what you ask "
Is there any way to connect ESP 32 and ADXL 345 so that I can read ADXL 345's data on a webserver"
Think about what you ask ericgibbs posted you links to those Now you have to work those into a solution.
Or Ask something that is your problem.
Like can anyone give me working code that connects ESP 32 to a ADXL 345 and post to a webserver that i can open in my cellphone and use.
I was able to connect ESP 32 to ADXL 345 , but i want to create a web server so that i can remotely access ADXL 345's data on my PC or smartphone , i tried to google and learn more about web sockets and servers and all , but the more i dwelled inside the more complicated it got, all the videoa and webpages are filled with MPU6050 sensors , which has different IDE library, i am having trouble to post it on webserver , as correctly said by be80beHi Arijeet,
Are you not able to use these two video's?
One showing how to connect the ADXL to the ESP32
and the second video to set up the web server from the ESP32.?
E
You may find this useful https://randomnerdtutorials.com/build-web-servers-esp32-esp8266-ebook/i want to create a web server so that i can remotely access ADXL 345's data on my PC or smartphone , i tried to google and learn more about web sockets and servers and all , but the more i dwelled inside the more complicated it got, all the videoa and webpages are filled with MPU6050 sensors , which has different IDE library, i am having trouble to post it on webserver , as correctly said by be80be
