I'm looking for an IC that will give me a low or high output bit depending on 6 input bits.
I'm trying to find a relatively cheap IC that will give me a high or low depending on a signal it gets. The signal is 6 input bits.
For now, I have a "digital comparator" in mind, where the 6 input bits will be compared to the 6 bits that I wanted... (it will be high if it's the 6 input bits and the "compare" bits are equal)
so the problem here is that I have to individually wire each bit (14 lines per chip, 6 input bits and another 6 compare lines to see if it's equal) . . . . . if there's other chips that can do this, it will be great.
(Even if we can buy something that is pre-programmed with something with the "compare" bits, it will be great.
