Were you able to see the attachments of the chip itself? I tried googling some of the numbers to see if the blueprints were online but found no results. It also looks like the 6 inputs go directly to a resistor of some sorts labeled ZOZ or 202?I know what dry contact are, thanks. I'm just not confident the document is accurate.
Usually dry contacts are available as outputs, not inputs.
And optocouplers used for inputs. This is to electrically isolate the internal circuits of the device from external voltages.
We need to know this before moving forward, so we can properly interface the new circuit to the device.
If you have a good reason for needing to know I can reach out to the manufacturer (Advantech). How would the input type change what circuit I need for this particular application?
