Hi all,
I'm calculating the components for a powerful LLC converter (3.3kW max).
At the moment I choosing capacitors for the resonant tank.
In general, I need to dial 62nF.
If using film capacitors, then I found 10nF and 1nF. I can connect x6 10nF capacitors and x2 1nF capacitors in parallel. Will come out about 62nF (accurate).
If I understand correctly, then the current entering the resonant tank will be evenly distributed between all parallel capacitors.
The only thing I did not find an answer is whether it is good that in this combination two capacitors have a capacitance of 1nF, and the rest - 10nF. Will this somehow overload small capacitors?
