Hello, I am very new to practical electronics stuff and I am trying to build an AM transmitter using TL072 OP-Amps and no inductors. I wanted to generate a 1MHz carrier wave with one OP amp and make a modulator with another OP-Amp. After reading on OP amps, i decided to generate a sine wave by Building a Phase Shift Oscillator. However after trying unsuccessfully to get 1MHZ, I Googled and read that the Phase Shift Oscillator is not meant for high frequency applications, as the reactances of the capacitors become negligible. So i decided to generate a square wave instead for my carrier using a schmitt trigger, and I was able to generate 1MHz (from my Proteus simulation). i haven't built the entire circuit yet. What i want to know is if the AM transmitter circuit will work fine with a square waveform as carrier. Thanks
