I am powering a class AB discrete amp. The question I have is by connecting the common to earth aren't we actually creating more chances of a shock. Since if we did not connect the common to ground and someone came in contact with the +ve or -ve lead of PSU there will be no shock unless he/she also touched the common. But with the common now connected to chassis because of earth ground; if someone touches the +ve or -ve lead and touch the chassis (which is far more probable compared to touching the common terminal) aren't they in for a shock (pardon the pun). I am almost sure I am wrong but I can't seem to explain myself.Hum elimination is a good reason. What are you powering with this circuit? Have you tried isolating the source of the hum and trying to filter the source?
Using earth ground provides a low resistance path for current to flow in the event of a short of a "high" voltage to the chassis. Without the case being grounded, someone touching the case could provide the shortest resistance to earth ground. 35-45V is not a dangerously high voltage under most conditions.The question I have is by connecting the common to earth aren't we actually creating more chances of a shock. Since if we did not connect the common to ground and someone came in contact with the +ve or -ve lead of PSU there will be no shock unless he/she also touched the common. But with the common now connected to chassis because of earth ground; if someone touches the +ve or -ve lead and touch the chassis (which is far more probable compared to touching the common terminal) aren't they in for a shock (pardon the pun). I am almost sure I am wrong but I can seem to explain myself.
No, assuming the wall outlet is wired correctly. In fact, connecting the secondary ground point to earth ground is a requirement for an SELV (Save Extra Low Voltage) output. Pretty much mandatory in medical equipment.The question I have is by connecting the common to earth aren't we actually creating more chances of a shock.
ThanksNo, assuming the wall outlet is wired correctly. In fact, connecting the secondary ground point to earth ground is a requirement for an SELV (Save Extra Low Voltage) output. Pretty much mandatory in medical equipment.
