Similar control design. What happens when the voltage at the non-inverting input is lower than the voltage inverting input?. The output is connected to the gate od a P-mosfet. Will that mosfet be continuously on or off? What happens is you remove charge current control from that charger?
I am not about to try it. If well designed, as I suspect it is, the charger will enter an overload state. Which comes first, thermal overload or current overload?
It seems we have moved -- not progressed -- from trying to resolve a legitimate question to answering questions about all the different ways to do it wrong. I am not interested in continuing on that path.
I hope you find something that works for you. Good luck.
