I only know of Digikey.com for finding spec sheets for some of the old junk I have. Well, I have this N-channel MOSFET (if it's MOS). I'm looking for the spec sheet for it. I'm only using it to drive a small motor and I'm certain it is more than capable of the task. However, I'd like to have the specs anyway.
Where do you go to find specs on various devices? As mentioned, I only know of Digikey as a source, and several times it has let me down. I also wanted the specs for an MPF102 N-channel JFET. At least I know it's a JFET. But I don't know its capabilities, and it might be too small to power this little DC motor. I'm using it in a PWM Motor drive circuit (below). If I have to I can regulate down the power, but so far I like the 12 volt speed this little D / V 5.9 (yes, that's how it's marked) motor can give. I don't know if I'm over-speeding it or if I should limit it to maybe 6 volts. The numbers on the motor are (if you care to give it a stab):
RF310T-11400
MD068212
D / V 5.9 (made by Mabuchi [made in Malasia])
RF310T-11400
MD068212
