Depends on how much current the motor draws. You could connect the motor to a 12VDC source and apply the 15Nm and measure the current.what is the maximum current rating of this circuit??i want to drive the 12v DC motor with optical encoder..having 15NM torque..will this circuit drive this motor??..
How much current does the motor draw at nominal voltage?.will this driver drive this heavy torque motor??..
What does that mean? What output current?its output current is 0.1 to 20 mA
You need to know the motor current with 15Nm torque applied.and no load current is 0.8A max..
Thread starter | Similar threads | Forum | Replies | Date |
G | H bridge problems using IR2110 | Power Electronics | 5 | |
B | h-bridge inverter using ir2110 causing problems | Analog & Mixed-Signal Design | 1 | |
A | ir2110 low side problems? | General Electronics Chat | 4 | |
I | ir2110 problems | General Electronics Chat | 61 | |
M | IR2110 High Side Problems | General Electronics Chat | 8 |
by Luke James
by Jake Hertz
