When it is powered from the RC circuit shown in its datasheet, its output goes low when it receives 38kHz IR pulses. When the 38kHz pulses are transmitted in bursts that are defined in the datasheet then the range will be maximum.Hi is there any option to check this TSOP is working good os faulty...?
