the 120 VAC is coming from the passenger jet bridge. From there it's coming from the airport so I don't know the actual details there.
When reading "something" about USB, I remember something about where the pull-ups can be removed by the IC. Doubt I can find it again, but it looks like I did.I just found it entertaining that re-setting the lightning handled enumeration, but re-setting the power button on the TIM did not.
So there is something going on with the Vbus rising edge that it does in fact need; and staying connected doesn't return the D+/D- to their pulled up or down states?
Suspend mode is mandatory on all devices. During suspend, additional constrains come into force. The maximum suspend current is proportional to the unit load. For a 1 unit load device (default) the maximum suspend current is 500uA. This includes current from the pull up resistors on the bus. At the hub, both D- and D+ have pull down resistors of 15K ohms. For the purposes of power consumption, the pull down resistor at the device is in series with the 1.5K ohms pull up, making a total load of 16.5K ohms on a VTERM of typically 3.3v. Therefore this resistor sinks 200uA before we even start.
Yeah I reset the TIM power and it would go to connected (100mA) almost right away, then SDP (500mA) at 10 seconds, and finally DCP (or apple charging) at about 20-22 seconds.https://www.beyondlogic.org/usbnutshell/usb2.shtml
#1. Make sure you try an decent amount of off time like 30s.
If VBUS is lost, the device has a lengthy 10 seconds to remove power from the D+/D- pull-up resistors used for speed identification.
Your USB meter, looks like it can interact.
So, you don;t have to wait an extraordinary amount of time at off?That’s good though. Re-plug can be done on either end it seems or by resetting the TIM
This https://www.st.com/content/ccc/reso...df/jcr:content/translations/en.CD00004193.pdf article is interesting.
One of the USB Compliance Checklist for Peripherals items asks the following question:
“Is the device’s pull-up active only when VBUS is high?”.
it might be worthwhile to monitor D+ to ground after a transfer?
This http://www.techunboxed.com/2013/06/usb.html would be useful. You can order the board. The components have to be ordered separately from the BOM. Bill of Materials.
You would need a short AB cable like: https://www.superwarehouse.com/Belk..._A_to_4_Pin_Type_B,_6_/F3U133-06INCH/p/484968
I think it also means that you could easily breadboard the "reset" circuit I suggested earlier.
The breakout adapter by itself, should also work, just by removing the VBUS jumper and re-inserting the jumper.
If that works, there is a excellent possibility that the reset gizmo would work.
Prove that and then try to get the MFR of the TIM to make the appropriate changes.
Well the good news is plugging the iPad to the TIM isn’t even mandatory so long as the iPad has a specific charge prior to starting the trip. So, you could go a day without touching one. I had never heard of mating cycles.I'd pick the power switch on the TIM.
Any cable is going to break. https://discussions.apple.com/thread/6185323 So do USB ports. They have a giant Lever arm on them. My laptop likes to fall on the plugged in cable which means a bad port on the laptop.
Socket savers exist: http://www.l-com.com/usb-usb-20-type-a-and-b-socket-savers but that just makes the lever arm longer.
I did have a Microsoft wireless mouse that kept breaking the base. I used this http://www.l-com.com/surge-protecto...pe-a-type-a-panel-mount-style-with-pigtail-12 surge suppressor to stop it. It just depends how the stuff is designed. The pigtail cable can also act as a socket saver too, but it's probably as expensive as a lightning cable.
With constant plugging, something is going to break. I've had USB cables break.
You have mating cycles. This https://www.iconnsystems.com/blog/connector-mating-cycles mentions USB and you have the flexing of the cord at the ends.
Litz wire https://www.coonerwire.com/litz-wire/ is probably the most flexible. Old telephone station wire was really flexible too. It was a flat multi-strand wire spirally wrapped around a core.
So, the wires break at the ends.
It might make sense to have a means of detecting cable faults. A lightning breakout is here: https://www.ebay.com/i/381376155289 . You can find ones for USB. So, you can wire something together with a bunch of LEDs, adapter or whatever so you can flex and test the cables or maybe adopt a replacement interval or keep a spare cord handy.
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Aaron Carman
