praondevou
- Joined Jul 9, 2011
- 2,942
Does this look about right?
The comparator logic is;Yes, upper and lower transistors form two common half-bridges.
Ok, if Q3 and Q4 are just having opposite gate signals you can tie HIN and /LIN of U2 together. I don't see a problem with that. Makes a variable ON/OFF time for Q3 and Q4. (Within limits).
What about the Comparator logic?
My understanding of the SG3525 family, there are other names for same chip depending on maker, is that the clock and PWM frequency are one and the same. It is like a 555 and lm339 in one chip. But also has other options built in, shut down, over current, etc.I don't know the SG3525 good enough. The oscillator frequency is twice the PWM, right? So the frequency after the 74HC74 would equal PWM. It would only be interesting to know if the phase is always the same.
There is also nothing that tells the 74HC74 where to start after power up. This however you can easiy accomplish with an RC at the RESET/SET input. I'm just not sure about the SG3525.
My question is: Would it be possible having a PWM signal ON while the output of the 74HC74 is inverted (OFF) in an unpredictable manner after each power up?
Don't Hin and /Lin need to be identical? The inversions required to drive Q2 and Q4 happen inside the IRS2183.OK, new timing diagram and schematic time. I think I have correct this time. Both cap banks, 'A' and 'B' are shown this time. And the timing for each of the switching components.
If you want the LO and HO outputs to be complementary, then HIN and /LIN must be identical (connected together). That's what this thread was originally about!Ron, the are identical, but inverted. Q1 and Q2 are driven by U1 making a half bridge. Q3 and Q4 are driven by U2 making a half bridge.
The way the logic is done, Q1 & Q2 are high twice as long as Q3 & Q4.
You are missing my point. Read post #8 again. Condition #3 in that post is what you have drawn in your timing diagram.Ron, I'm missing some thing here? The individual half bridges are complimentary. When U1 Hin is high /Lin is low. When U1 Hin is low, /Lin is high. The same for U2.
But there are two different IRS2183 chips. Each is controlled by a separate signal from the logic circuit. So as the timing diagram shows Q1 & Q2are compliments, Also Q3 & Q4 are compliments.
I don't know any other way of showing it. Or I'm missing your point.
Have you forgotten that this was the original topic of this thread? From your post #12:Ron let me think on this, and try to figure it out. This is all new to me. I will return.
I'm assuming you meant that you wanted to be able to drive HIN and /LIN with the same signal. Well, you can!My reason for wanting to use this chip is eliminating the use of an inverter chip in my logic circuit.
You probably think I am anal, but your timing diagram does not agree with your schematic. See the first attachment. I realize you have the Q number designations on the same line, but those are not unambiguous, because they could refer to source or drain voltage or current, or gate voltage (which I now assume is what you were intending). I think you will agree that showing HIN and /LIN tied together on your schematic, and showing them as opposite polarity on the timing diagram, is potentially confusing to anyone who is not you.And I have shown that in my schematics. Right at each IRS2183 the pins are connected together. I'm including drawings that are color coded showing the logic circuit, switching circuit and timing diagram.
The whole reason I started this thread was to find out ;
1. if the drivers worked the way they do.
2. to find out if using them would work to recharge the boot caps. Since the principle fets Q1 and Q3 are in a high side configuration.
After studying the block diagram and the schematics in the datasheet, I am pretty sure that PWM output A and PWM output B are each at half the oscillator frequency, and alternate with each other.RON, did you find any info on how exactly PWM outputs and oscillator frequency are related? I can't find a timing diagram for the 3525.
In order to check the logic circuit one need to be sure what comes out of the 3525.
by Jake Hertz
by Duane Benson
by Duane Benson
by Jake Hertz
