Im currently doing my final year project which is the intelligent grounding system... But im not sure abt certain parts of my project, and i cant ask my advisor too since is away, his having a minor operation and will be back in 3 weeks times... So the project to put in a nutshell, can be potrayed as the following
scenario:
When the sun is at its peak during the day, the light intensity is very high. The sensor will sense this intense lighting and thus its resistance will decrease. The sensor will trigger the water sprinkler into operation, whilch is basically operate the valve in order to pour out the specified solution in order to decrease the resistance value of the ground.
My idea of doing tis project is by using a ldr sensor which after doing some experimental work i should be able to predict the ground resistance according to the light intensity.The output of the sensor will be interfaced to a microcontroller and the output of the microcontroller should be like a time based output which opens the sprinkler for a certain amount of time depending on the increase of the ground resistance and pour some type of solution in order to decrease the ground resistance to the optimal level... Will this work? can anyone please point me to the stuffs that i should be looking at for the sensor and micro-controller in order to design them... im assigned to the sensor and microcontroller part of this project... any opinion would be welcomed... i really need some advice... thanks in advance
scenario:
