Inspire P580 problem
R!f@@
Joined Apr 2, 2009
9,918
Wow ! I took too Two weeks off. Didn't know tht.
I need some more info.
See the pdf,
Post the no. on the IC 1 & 2
And gimme the pin orientation of the 3 M51132L's. The 14 pin in line IC's marked with the joined 3 arrows. I need to know where pin no 1 is. ( towards the heat sink or away from it.) It's a bit confusing to find out u know.
kuza
Joined May 11, 2012
41
1. TDA851J
N3K5E3 03
HSO4402 2
2. TDA 8511J
N3E6R9 13
HSO351 2
Dont know how to find orientation,IC's don hawe any marks (dots or such). I assume 1. pin is at front left side(side with the numbers) of the IC and it is towards the heat sink.
R!f@@
Joined Apr 2, 2009
9,918
Having a bit of hard time tracing with a poor pic.
Can u post a pic of the back jack connection details. I like to know which are which. That is the inputs and front/rear speaker jacks.
kuza
Joined May 11, 2012
41
Cant do it now...ill try tomorov. Im bit drunk tonight, team celebrate wictory and going in play off-s
kuza
Joined May 11, 2012
41
Thank you R!f@@ for you'r time and help!! I think and hope that this will help a lot of people with same problem.
