Sparky,
The circuit which you gave me is not working as planned.
My one transistor circuit works like this;
As soon as the float switch is closed the transistor switches on and the LED illuminates.
No matter how long it is closed the time delay will only start when the switch is opened. It will reset as soon as the switch is closed.
With the 555 the timed period starts immediately when it is triggered and continues regardless of the switch being opened or closed.
I can overcome the dimming effect by employing a relay . This works perfectly and achieves the desired effect.
Thanks anyway for your effort and help.
Good luck
Good luck
