Should never use it to power another chip. Use it to control the reset pin instead.Use another 555 as a photo switch like this,,
Why reinvent the wheel!
The chip in a solar garden light has a pin for the solar cell that senses daylight and does all the switching with very little extra parts.
The colour changing variety generate about 4 - 5V, which would do for the original circuit if a CMOS 555 was used.
The TS mentioned an LDR - they're getting hard to come by because the toxic cadmium doesn't sit well with RoHS. That's probably why the abundantly available garden light chips use solar cell charge current to sense daylight.
A discount store local to me is offloading colour changing garden lights half price - ATM: I'm savaging the LEDs for PC PWR LEDs, the solar cells, inverters and any other useful bit go in a box till they come in handy.
Sorry Dodgydave, but I do not necessarily WANT to use a 741, it was purely the first device I chose to use as a comparator, it could have been a LM393 or even perhaps a LM311 or some other comparator but it was a 741.that was suggested earlier on Ian posts# 7,12....this guy wants to use a USELESS 741,,,
Thank you dannyf for your support. I am very grateful with the comment you left.So let's focus on helping this guy, rather than telling him how inadequate he is in using the 741 here.
The 741 is plenty adequate for such a simple job, but a comparator would be technically a better choice. A little positive feedback to give it some hysteresis and you wouldn't know the difference from using a comparator. Maybe try about 1M from output to the + input, if it takes too much change in light level to switch - use a higher resistance.Sorry Dodgydave, but I do not necessarily WANT to use a 741, it was purely the first device I chose to use as a comparator, it could have been a LM393 or even perhaps a LM311 ot some other comparator but it was a 741.
Actually, unlike most opamps, the 555 output stage is good for a few hundred mA, and can easily power 25 or 50 mA of downstream stuff. (with appropriate decoupling, or course)Should never use it to power another chip.
Outstanding response.Apparently - its possible to use the741 as a noise generator.
That's not the kind of noise he is talking about.So what? Any device made by man, including your super duper opamp, can be used as a noise generator.
That is.The whole 741 discussion is meaningless
Actually...if you read my responses to you and others in this thread, you will see that I agree with you that the 741 is not obsolete, is still being designed into new products, and can work well in this application with a little help. What I disagree with are your reasons for supporting the 741. The fact that it is old definitely does not make it obsolete or instantly unqualified for this application. However, the fact that it is old and still in production does not make it a good choice for your circuit in post #1.Ok, you are clearly a hater of the 741 and consider it should be made obsolete
The 741 is a well established functional block that has stood the test of time - but there are more recent parts optimised for specific advantages, the list of applications where a 741 just won't do is slowly but steadily growing.Actually, unlike must opamps, the 555 output stage is good for a few hundred mA, and can easily power 25 or 50 mA of downstream stuff. (with appropriate decoupling, or course)
ak
ak
That is.
ak
ak
"Hater" - Did you not understand this? It is an English word. Look it up and read the definition."hater" - really? Are you 12?
ak
It is really quite simple. You have two key elements to your circuit that you need to determine:I am still not certain which circuit to choose
Thank you dannyf. Can I ask which software you use to design circuits? .. as something like this would help me a great deal.Here is how the switch + light sensor can be done:
It is a pnp driven by a tl431-based light sensor. R2 is the LDR (on resistance around 5K and dark resistance over 100K). R1 is pikced so that the switch turns on at LDR = 14K.
It works with mosfets too but does require 5Vcc or over for most mosfets, and works down to 3.3Vcc if pnp is used. You can replace the tl431 with a n-ch or a npn - need to readjust R1 however.
Once you understand how it works, no need to worry about the minor stuff, like if a 741 is too obsolete to work here.
by Aaron Carman
by Robert Keim
by Duane Benson
by Jake Hertz
