I have a Stemma QT Py with a tiny LED that I'm trying to make into a portable device. Currently it only works with a USB C connection. Can I solder one of my 1S RC batteries to the back on the USB's pads?
What voltage are the batteries?I have a Stemma QT Py with a tiny LED that I'm trying to make into a portable device. Currently it only works with a USB C connection. Can I solder one of my 1S RC batteries to the back on the USB's pads?
There are also little boost circuits you can use to get 5V from as little as 1.8V in. That would make the 3.7V battery an option.Easiest way: use a USB powerbank. The ones with one cell are quite small.
Bob
Unfortunately the device needs to be small. Really small, like roughly the size of a quarter. I'm prototyping an idea I had, but I'm not directly telling you what it isWhich is exactly what the power bank is. And he can just plug it right in, no wiring required.
Bob
All my batteries are for flying RC planes. I have little 220mAh 1S (single cell) at 3.7v, as well as 2S 380mAh (7.4v). I'm pretty sure the 3300mAh 3S and 5000mAh 4S batteries are way too much, and I'm not donating my $60 6S batteries to this project lol.What voltage are the batteries?
If you never plan to power through the USB connector while a battery is connected, you can power with a 3.7V battery connected to the 5V pad.All my batteries are for flying RC planes. I have little 220mAh 1S (single cell) at 3.7v, as well as 2S 380mAh (7.4v). I'm pretty sure the 3300mAh 3S and 5000mAh 4S batteries are way too much, and I'm not donating my $60 6S batteries to this project lol.
Oh, okay, I didn't know it was that easy. That's correct, I don't plan on using the USB with a battery connected, but I still need the USB to connect to the computer to make changes. So just to clarify: I can simply solder a couple leads onto the 5v and ground pads under the USB for my battery connector and plug in? The voltage range for these batteries is 4.2v down to 3.8v (maybe 3.7v since the voltage sag won't be nearly as bad as a plane).If you never plan to power through the USB connector while a battery is connected, you can power with a 3.7V battery connected to the 5V pad.
Otherwise, you need the recommended diode and need a battery voltage that's appropriately higher.
