Yes, the fans will be 5Vhi,
Please confirm that you have a 5V relay on the Temperature module.
I assume the Fans are 5Vdc.?
E
E
Thanks, studying it now.A simple Google of "bimetallic thermostat switch" will bring up plenty of explanations and illustrations. Normally PC fans are 12 volt but you can buy an 80mm 5 volt fan. Control can be as simple as ON/Off or speed control based on temperature simple to complex. Matter of fact computer parts houses sell fan controllers really inexpensive.
Ron
The idea of switching an electronic component for a mechanical device sounds great, makes for reliability and cost. Thanks again.Sorry, stats = bi-metal thermostats.
Now I am worried. Hopefully you know that a fan will not lower the temperature below the temperature of the air it is blowing. Since you seem to be right in the range of normal room temp, is this device going to be operating in a place cooler than that?The temperature to which the thermostat will be set to will be within 72-78º Fahrenheit. In some rare occasions, people might set it as low as 60º, but I wouldn't need to guarantee it could lower the temp that much.
No. The bi-metalic strips measure ambient air temperature, not water.I need a probe. ••• Can you add a probe to these thermostats?
Sorry, that's not likely going to work. Though I do believe the better ones use electronic temperature sensing.Look at this aquarium heater I found, for instance.
Hadn't thought of that. This is a design consideration for sure. Blowing away warm air and replacing it with warm air does nothing to cool anything. To exchange heat you need a temperature difference. But I'll leave the design up to the thread starter (TS).Now I am worried. Hopefully you know that a fan will not lower the temperature below the temperature of the air it is blowing. Since you seem to be right in the range of normal room temp, is this device going to be operating in a place cooler than that?
Hi Bob,Now I am worried. Hopefully you know that a fan will not lower the temperature below the temperature of the air it is blowing. Since you seem to be right in the range of normal room temp, is this device going to be operating in a place cooler than that?
Bob
No, they are powered by 12 VDC and are stand alone. They normally include sensors, mostly thermistors which with a few drops of nail polish or epoxy are easily water proofed. Could easily be powered by a 12 volt DC wall wart. Just remember you want an automatic and not manual. That or roll your own but knowing now this will be submerged changes things as now you need a sensor made to be submerged. Rhere anything else we should know?Those PC fan controllers look beautiful! But they are controlled by the motherboard right? They're also powered by it. I would need it to work with the thermostat and the 5V power.
Sorry, Ron, dont want to give you guys the run around at all, in fact just the opposite. I just dont want to fully disclose the product itself but I believe I can give you all the information you need.No, they are powered by 12 VDC and are stand alone. They normally include sensors, mostly thermistors which with a few drops of nail polish or epoxy are easily water proofed. Could easily be powered by a 12 volt DC wall wart. Just remember you want an automatic and not manual. That or roll your own but knowing now this will be submerged changes things as now you need a sensor made to be submerged. Rhere anything else we should know?
Ron
BrilliantIn High School, myself and a couple of friends built an evaporative cooler for a salt water aquarium. Two acrylic tubes were drilled to appear glass capillary tubes. A cotton cloth was then woven through the c tubes. This device was put in series with the filter pump, one a tube was placed in the water and water was drawn up the cotton cloth by capillary action. A fan blew across the cloth surface. We dropped the temperature of the aquarium water by almost 10 degrees.
When water evaporates it cools the surface it's evaporating from. The air also? Sure, due to the transfer of heat between the cooled surface and the air. Thats why wind is so cooling after exercising, when you're drenched with sweat.Here's what I know about evaporative cooling: And this is not going to be the "Be All - End All" of the story, but as far as I know, water evaporating cools the air. And the way water evaporates is if the humidity is low. High humidity is poor for evaporative cooling. This I know because I live in Utah; a typically dry climate. A few days ago we had higher than normal humidity and the swamp cooler (evaporative cooler, or "Swamper") didn't offer much relief. But with the dryer weather the swamper works great at cooling the air.
I don't know if the water is cooled too, it probably is. But that's because the water is flowing over a medium that creates more surface area for the water to evaporate. The reason why evaporation cools is because it takes energy. Energy right out of the air. Leaving the air at a lower energy level. And if you remember science class, hotter air has molecules moving faster and at higher energy levels than at colder temperatures. So when you trade off energy for evaporation you get cooler air. But I don't think you're going to get much cooling just blowing air over the surface of the water.
That's my 2¢. I'm sure there's another 98¢ to the story but I can't speak with any authority on that subject.
As far as cooling the water - if there's a heat pipe (thermally conductive pipe) in the water and the fan is blowing colder air over the warmer pipe then it will cool the water. Think "Radiator". But then again, I'm short a buck.
No problem at all. I used similar rack mounted fan systems in test stands. Anyway if all you want is simple On/Off based on a set point temperature look at some of the temp controllers which use a thermistor. You are looking at a narrow range of temperature and if you can do with +/- a few degrees and there are cheap boards off the boat like this one.Sorry, Ron, dont want to give you guys the run around at all, in fact just the opposite. I just dont want to fully disclose the product itself but I believe I can give you all the information you need.
I made another sketch that might help narrow it all down:
When I kept tropical fish in North American I used these to maintain water temperature. It is very simple inside a bi-metallic switch connected to a knob so the temperature can be set, connected in series with the heater, which was probably nichrome so it would have low resistance.
by Jake Hertz
by Jake Hertz
