The Electrician
- Joined Oct 9, 2007
- 2,970
The ~400V that is momentarily present on the cap during the secondary arc doesn't remain on the cap after the arc is over to help during the next cycle. After the arc is extinguished, the voltage on the cap quickly becomes equal to the battery voltage, assuming we're talking about the circuit shown in post #4.The capacitor also gives an extra ~400V to the primary of the coil, when the engine is running. This ~400V comes from the voltage spike stored in it. Due to the preceding cycle of the system.
Again assuming we're talking about the circuit arrangement shown in post #4, the voltage on the cap each time the points close is just equal to the battery voltage. The relatively high voltage the cap "charges to" during the secondary arc doesn't remain on the cap for long. It's gone as soon as the arc is over and certainly doesn't last until the next closure of the points.That seems like a stretch as far as being why they call it a condenser.
If sized properly, it prevents a spark from forming at the points at all -- upon opening anyway.
Since the voltage can't change across the capacitor (and if you buy a replacement in an auto parts store they are almost always labeled as condensers) instantaneously, the voltage across the points has to change continuously, starting from zero, as the points open. As the voltage builds in the capacitor, so does the voltage across the point gap. But the point gap is widening while, at the same time, the energy is being expended in the spark at the plug. If the capacitor is big enough, the voltage across the point gap never reaches the value needed to create a spark. If the capacitor is too big, it will rob too much of the energy and reduce the spark strength. As the points close, they are closing on a charged capacitor and that is when any spark happens and also when you get the greatest current through the points as it rapidly discharges that cap. The smaller the cap, the less energy has to be dumped, but the higher the voltage it will have charged to and, hence, the earlier in the closing motion the arc will strike. Its primarily this arc that pits the points in normal operation, as indicated by the much smaller pits compared to those seen when the condenser fails or is removed.
