You could try shoving it into a pipe, so its torpedo shaped, obvious balancing will be a issue.
That or using a wire to power the rov. Obviously this is a idea, not a good one but hay its a idea. What if you stepped up the 12v from the battery to 220v . Sent it down the wire and you can get modules that will turn it back into 12@1A and 5v@1A.
1a isnt great but its not a actual torpedoe.
