I took the plastic off and it's simply a shiny very dark reflective surface. At the right angle I can barely make out what's behind it. Best I can describe it is ~6mm circular reflective(mirrors? idk) placed in rows one after another that takes up the entire surface underneath.
It uses a 5-pin mini-din connector on both sides
It has an adhesive base plate that sticks to the bottom for aesthetics and two little screw holes that attach to something..
I opened up the plate and learned absolutely nothing.. lol
Just this one PCB connected to the mini-din as well as a small connector to the little green light at the front.
Any thoughts? xD
Any thoughts? xD
