Yes I don't disagree/I am not fundamentally opposed to that.Thanks.
It is cheaper and more efficient to throw something away and build a new one with new materials.
Or is it? When we don't factor in the cost of cheap energy, priceless resources and long term environmental destruction, the price we now pay is greatly understated.
Our expansionist monetary system relies on ever increasing levels of consumerism and consumption. Almost everything we do today is non-sustainable. Sooner or later we will face the consequences.
Timing out IS a reset. The manual reset button is only used to terminate timing early.Works, but after time out...
Press S2 (TRIGGER) LED2 = ON, Relay ON (Should ignore button press, no LED, no Relay, until reset is pressed.)
All above is correct?Not possible. Of course unless something is wrong.
After time out, LED1 = OFF, LED2= OFF, Relay = OFF.
Measure the voltage at U2B, pins 4, 5 and 6.
Pin-5 should be 0V
Pin-6 should be 11V
Pin-4 should be 11V
Since pin-5 is at LOGIC LOW, pressing S2 should have no effect.
Now you're confusing me again. Are you asking a question or confirming the above is correct?All above is correct?
