Identifying a Log Pot
beenthere
Joined Apr 20, 2004
15,819
If there is a manufacturer's name and part number on the pot, you can get that information from the web site. You can also use a meter and observe the change in resistance over a few degrees at either end of travel. A log taper will show much more change in resistance at one end than the other.
hgmjr
Joined Jan 28, 2005
9,027
Another quick check is that when you set the potentiometer to the approximate midpoint, the two resistances will be pretty nearly the same value if the pot is linear.
hgmjr
