I want to build a basic duty cycle generator. I assume a 555 timer will be used. It will be used for general projects, and a fixed frequency would most likely work just fine. I would like to be able to use it for motor speed control, "Dimming" LED's, and various other things. I found this diagram at www.555-timer-circuits.com listed as an "LED Dimmer":
I would guess that the "LED Dimmer" is basically a duty cycle generator (Says 5%-95% adjustability), but I can't even get their diagram to work for it's intended purpose anyway. I don't quite understand how that potentiometer with those 2 diodes facing the same way connected to it would do anything either. Thoughts? Better idea's for my project?
