Hello there, i'm a new user & i'd like to ask you about the icl7107 possible zero reading trigger-offset.
I made an amp meter 2 years ago & it's still working perfect but from the power on status i have a minimum reading current 14ma this measurement is the result of a minimum device consumption, i want to remove it from the panel meter i mean there is no need to see this measurement the better is to have this consumption but the meter it must read zero. I tried to offset the icl beteewn the pins 30-32 but without success. Is it possible, can i read zero even i have 14ma current through the panel meter?
Thank you for your possible help.
Cheers
Cheers
