I'm using a PCA9532PW IC that uses I2C. I have four of the ic's on a 10" x 1.5" pcb. They are evenly destributed in the vertical direction. I'm not clear what is the correct layout method for the SDA and SCL lines. Can I use a two layer board or is a four layer board best?
Thanks,
Thanks,
