I have a chip that has 2.0" I2C traces leading from the microcontroller up to it (3.4Mhz max). Will this interfere with the 2.4Ghz transceiver that is also on the same PCB?
I looked up the wavelength for 2.4Ghz and it is 0.125 meters (4.9"), but I am not able to determine if this is a problem. If this is a problem, what can I do to correct it? (I cannot shorten the I2C lines, they have to be in this specific location).
Thanks and any help is greatly appreciated!
