Van will be parked at bottom of yard with only a 10amp supply (220v) charger requires a 13amp supply. I realise if you lower the draw the charging time will increase and that is not an issue. I would like to almost trickle charge at 5amp so can still have lighting. I can't see how slower charging will reduce battery life but Nissan only make a 13amp charger that will overload the circuit.
Ideas please?.
Ideas please?.
