MeNC is driven by the proven and reliable EYEBALL MkI system. Mine is getting a little worn, but finds the pie in the fridge.
I've only ever made two boards this way, and etched a board way back in College (crowd makes woooOOO! noise). Grand total of Three(3), three count 'em. Three boards.
Here's how I did it.
I print out the trace pattern in photo reverse, glue it on the copper with shellac, and make all the black lines disappear @ the mill. With a little time spent in Paint the photo reverse image could be left with nothing but black dots and black lines, so after the milling and drilling, there would be a piece of paper stuck on a board and, when finished, there should be no black lines or dots left on it anywhere.
Strip away the shellac by a few minutes soak with denatured alcohol. Prep the copper for a sealer by scrubbing with fine scotch pad and cleaning with alcohol. place self stick dots or squares over all solder holes(I use squares, since most self stick paper has scraps left over after printer use; you cut it from that) and paint with good enamel lacquer or epoxy based paint. Peel off the solder masking spots by tracing around them lightly with a razor knife.
Screen print the artwork if any is used at this point. Result is polished looking board with small scale commercial potential.
Edit: All the above occurs AFTER you have tested the spacing of your artworks hole layout as it comes from the printer. Reducing and enlarging is almost a certainty, so have a good image editor, and never save over your original raw picture file, rename the test pics.
