I made an inverter in LTSPICE and it's not working
pkms37
Joined Mar 18, 2021
6
The circuit below works well
I refer to the netlist above and wrote the subckt file.
but the one with the subckt below is not working...
pkms37
Joined Mar 18, 2021
6
Oh thanks Bordodynov!
By the way, I don't know much about the circuit and the parameters that I have to put.
So could you please let me know which parameters I should consider?
I thought it would be okay with the default values.
And what is the difference between the circuits I uploaded? with symbol and without the symbol?
LvW
Joined Jun 13, 2013
1,760
Just a small hint: In all simulation programms all nodes require a DC path to ground (an open circuit can be simulated with a resistor of 1e12 ohms)
Bordodynov
Joined May 20, 2015
3,180
Transistors with default parameters are very weak. W=L=100µm. VTO=0. They are not suitable for your case. The difference between the subcircuit and the circuit on the transistors is in the error. In the subcircuit the drain and gate of the transistors are mixed up. Look at my subcircuit diagram. I made a rearrangement.
pkms37
Joined Mar 18, 2021
6
As I see the SUBCKT model you showed me, the parameter values are very specific.
Is there anywhere I can refer to for those kinds of parameters or does it comes from the understanding of the device and the circuit?
