You need a current limiter.the last led i had blew out it had 9 chips and only 3 would turn on thats why i think it needs a driver or something
1. If you intend to always use the led from the power supply then all you need is a resistor. You have plenty of power so there is no reason not to use it. As someone above said maybe not the best choice but it is the most simple.
2. If you intend to eventually power the led from a battery then you will want to use a driver as they are more efficient.
But led drivers are not usually found on PCs.
