I have set it to 1 message per 2 seconds and baud rate 9600. And yes radio link have rs232 connectionhi um,
I would select the GGA message at 9600 baud for the GPS unit, at 1second rate.
Does the radio have a RS232 input.?
E
E
I think you are going to have to buy or build a mux (multiplexer) to make this work.Like this, I know this is wrong but I tried to check what will happen. Now I need to make some delay function here or make a one string to receive for all data.
Yes that is what I want too priority of messages. One more question, can my ATmega 328p handle all these information at once?hi um,
As I stated, the GPS message and Sonar message and motor RPM message will arrive at the Atmega
asynchronously.
So you will have to assign a priority status to each Serial input signal source.
I would suggest a priority of GPS > Sonar > Motor > Battery.
What equipment do you have on the shore based receiving end of the project.?
E
Is the ATmega on the boat?it is ATmega328P-PU version. and for echo sounder it is 10 depth soundings per second
Sir this circuit is designed by me and Kordil is my company name.hi ume,
Checking that PCB, it is very basic, I would it say it is not suitable for your project.
BTW: I searched for Kordil ATmega PCB, no luck, all I got was Porn site......
E
Update:
Buy one of this type.
https://www.ebay.co.uk/itm/Arduino-Mega2560-R3-Compatible-Board-with-CH340G-UK-Stock/393110287475?_trkparms=ispr=1&hash=item5b8732f473:g:3nUAAOSwcL5gXcgY&amdata=enc:AQAFAAACcBaobrjLl8XobRIiIML1V4Imu%2Fn%2BzU5L90Z278x5ickkyMJZWL%2BqFSgQ3TOOe%2FNr7tH%2FjayHBT7wb94XTFzZ%2BuWQeUwnR7nLry6V0tJZROiY%2BwyUm5XhrlfO%2FoX8QUmk5ahup2Mkt5yra9k%2BsESwWfUhRfft%2FVpAazImi7UxLfGiT1I9pDl6V25ZK6M8wqSVgTW6999rXCI3FJm8HskVaHJM%2FINL1%2BvX5A92DNe2aaZYaeSwdoMqa8HZ5KEJzomMFiUwHwXU1%2BPxFpneNNz6qmwMa5SdJZzjcMZkuHgRV0dAmZ3mOGihnKCd1yp2hB7RQNamZnlm7lf8uK5NyNwE5ZlF0EJ1B3rVqie1qZB%2BQqpH1l2rhWx62mzfuPocETkIF6AR77p4dTMtVp%2BaIbZ93dyBLa89ESwzLPGOxuH1sX3UrkNCw1j3zHo3K%2FOFwdaDYGyYDabOlW%2BLtgS5Rm377yLn8Zy30mBjhsbNnnJFaYowCtS348taILatoa1dbY3v7cSncqwhaZx7lSdjc%2FbaPpNxtC9dpHDSq1GT7ywLs1gqj82DInKUJdFdWDNvkAFcFCyWKqODeT0cWQ1ArUhmw3TIQvhnwrt6CQEwGF30ES0bBJ36UtPPxz4Rv7Vh2gamCMwFz6lACN%2BUJFgf3if3QbeupfAsX%2F7mIAYmNQFX3MAlxfegwRuZMAjnamIIe5onyO%2FCeaSHc93n3mM96owygLk8ZwEyYPw3Q9THb%2FBuCj%2FUFBzU9iPwCyRWvLjmqbafFZD5IfNYhfT6RxZPmmgmsGWURUV2pA5oPyicl6Io2BvBOqYZk0rvBb2WLieReqJkvw%3D%3D|cksum:3931102874756db45ceb30444ea6b5cbc936045f776d|ampidL_CLK|clp:2334524
You need more serial ports so you can handle the various serial devices. You could redesign your board to include them, or you could buy one that has all the ports. Either way, you need places to connect your peripherals.So what should I do now? Kindly tell me.
Eric: I will standby. I was trying to be complementary, not replace your advice which I can't duplicate.hi ume,
I will let Yaakov advise you, you are going to get confused by too many idea's being posted.
Please let me know how your project develops.
E
by Aaron Carman
by Jake Hertz
by Jake Hertz
