I mean 12:30:45.001.hi,
Do mean
12:30:45.001
or
45045000 milli Sec
BTW: Did you try the depth SD logger program I posted.?
E
#241 ?hi ume,
That sounds very unusual , do you have document for the Weather station to post.?
E
If you are concerned about the 200μA used by the DS3231 we might need to discuss your battery arrangement…Will it consume less power than DS3231?
The 200μA of the DS3231 is the least of your concerns. You need to worry about the other parts and make sure your battery is up to the job.Actually it is a datalogger for weather station. So I am a bit concern about power consumption. Because it will have an atmega328, airmar 200wx and sd card and a DS3231.
Do the NMEA sentences not include timestamps? Does it have to be precise timing (that is, does it have to synchronize with other events recorded with high precision, high accuracy timestamps) or is it a matter of local correlation with events in the log only?Sir, I will explain you. Actually, it is a requirement from my boss. So we need time logged in at least 0.1sec. Tracking data with respect to time.
Then do the NMEA strings include timestamps? The weather station can provide 10 Hz GPS, maybe you could just run log.It is a matter of local correlation. Because in this circuit we don't have anything else connected.
