I suspect the ON/OFF circuit (12VDC) due to the unit powering up as soon as the power supply is plugged in. (120vac input with 4 pins on the output. I believe 2 are 12VDC and 2 are GND). The system is supposed to turn on with the power button after plugging power supply in.
So what happens after plugging power cord in is the LOREX logo loading screen comes up with a bios loading bar that stops at 3/4 way and locks indefinately. I tried replacing the hard drive just for yucks but is not the problem. If I try to power down by pressing the ON/OFF button nothing happens. the only way to power up is to plug in and the only way to power down is to unplug. I need help on where to start looking as there is no signs of heat on the board(s) anywhere. any input would be grateful. Thank you in advance.
Also, Lorex tech support is no help whatsoever. Worst tech help I have ever come across.
