- Joined Jan 23, 2018
- 18,574
Halogen lamps ARE incandescent types but because of the halogen gas filling they can have a much hotter filament but stipp the filament does not fail rapidly, because of the halogen group (Hydrogen, Chlorine, Florine, and Bromine) gas. So because of the hotter filament they give off a lot more light, and also a lot more heat. So there may be an excess heat problem. You should monitor the temperature of the lights for the first hour or so by feeling the outside of the lense every few minutes. if they get too hot to touch then switch them off.Hi Ron,
-I always thought that halogen lamps and incandescent lamps are the same thing,not to mention that I had no idea that halogen lamps are hotter.
Is there possibility to install incandescent lamp instead of halogen?
I personally wouldn't mind if lamp get hot,but I'm worried that it will damage base and cause fire.
-Another thing that I don't understand is how can I install halogen bulb in that light if it's not made to simply screw it in?
-Anyway,to summarize things-is it possible to install halogen/incandescent bulb in lights I bought and connect them to board?
Will average electrician be able to modify them if that's even possible?
EDIT:my home voltage is 230v and board works on 85-250v.
Lights are 120VAC
Thank you once again Ron.
