I havent started yet, cant get my head around what values or what type of coupling i should go forhi,
Post your attempt at answering, we can then help.
E
Alright I will try nowWelcome to AAC!
Take a close look at your specifications. There are many hidden hints there. 2, 3, and 6 are important design criteria.
4 is confusing. There is only one way to achieve 0Hz low-frequency cutoff.
Since this is a multi-stage design, think three stages,
(1) preamp
(2) driver
(3) power output
Hi and welcome to the forum,
Sorry, sounds like it's going to be a rough semester.Yes I honestly have not its for this module I have, but I cant really comprehend it, it is on npn transistors
Oh ok so can you design a single transistor amplifier with specs whatever you want them to be for now?Yes I honestly have not its for this module I have, but I cant really comprehend it, it is on npn transistors
If you're not doing it and we're not doing it, then who do you suppose is going to do it?LOL Thank god im not doing it again
I am not sureOh ok so can you design a single transistor amplifier with specs whatever you want them to be for now?
Let's say 1 volt AC input and 2 volts ACoutput. Can you do that?
Mechatronics EngineeringHi,
Doing what again?
You did not really design this. It looks like you just threw components onto a schematic without understanding anything. This design won't work because the transistor Q1 has no DC bias. A usual starting point is to put the quiescent point (Q-point) at Vcc/2 or +6 volts. How could you do that? Here is how you can do that, but that is not enough because your output is only 6 mV P-P. You have not made an amplifier, but an attenuator. Do you know why?I am not sure
I have no clue, how?This design won't work because the transistor Q1 has no DC bias. A usual starting point is to put the quiescent point (Q-point) at Vcc/2 or +6 volts. How could you do that?
for a dc bias, is it that you add a resistor next to R1I have no clue, how?
2VIf you're not doing it and we're not doing it, then who do you suppose is going to do it?
Lets start with the gain. If you have 20 mV P-P and a gain of 40 dB, what will the peak to peak output voltage be?
No, See edited post #16for a dc bias, is it that you add a resistor next to R1
