I would have to take a few issues with that, magnet. First, with a solid state tesla coil you rarely have to calculate the capacitance of the topload anyway. Usually the primary frequency is adjusted indirectly by a pot, so a pair of semi-spherical bowls should work. I've heard of people using them before.could work, but it might be a bit difficult to calculate it's capacitance
I'm not experienced in SSTC's, but for a SGTC I know the secondary must be very closely in tune with the primary resonance circuit
A decent sized torus can be obtained for about $90
A sphere for much less, but it will only shoot up
Are you already at all familiar with the general operation of a tesla coil?
If not then that would be a great place to start
Also, 4hv.org forum has a dedicated tesla coil board, many of which are audio-modulated, if you need something to look at
http://4hv.org/e107_plugins/forum/forum.php
[EDIT]
you're going to want to see this
first video-
http://4hv.org/e107_plugins/forum/forum_viewtopic.php?125121
Also, a sphere will not cause it to "only shoot up". The streamers will "crawl" all over the surface, going out to the side, arcing upward, and even downward. I would agree, however, that a torus is often better. I also agree that R!f@@ should do a little research about how Tesla coils work in the first place. 4hv is okay, but I rarely get good answers there. I have found them to be less friendly than the members here or on Electro-Tech. You could probably read up on some of the threads there, though. It'll help you put this project into perspective.
Regards
