I am basically looking for a 12v D.C. 24 hour seven day timer that turns a motor in reversing on and
Need help it's seems to be simple but I can't figure it out
  • Timer
    Votes: 0 0.0%
  • Motor reversing
    Votes: 0 0.0%
  • Total voters
Drfog
Joined May 25, 2017
I am basically looking for a 12v D.C. 24 hour seven day timer that turns a motor in reversing on and off
Example. I need it to turn on Friday at 2:30 AM motor starts for 30 seconds turns off then two hours later the motor switch it to reverse for 40 sec. to close
Regards,
MaxHeadRoom
Joined Jul 18, 2013
22,011
Is this battery operated or AC powered?
One avenue would be to use a small irrigation timer, they have real time clocks and 12v ac outputs which a bridge could be attached to , one output could be used for a reversing relay .
(p.s. I recall now they could be 24vac.)
Max.
Reloadron
Joined Jan 15, 2015
5,720
Per Max an irrigation timer with a RTC (Real Time Clock) or a small PLC (Programmable Logic Controller) with a RTC. Entire packages can be bought for less than I could ever build one for.
Ron
Drfog
Joined May 25, 2017
One avenue would be to use a small , they have real time clocks and 12v ac outputs which a bridge could be attached to , one output could be used for a reversing relay .
Max.
i looked at irrigation timer they dont allow sec. in the programing also all is 12v dc
Drfog
Joined May 25, 2017
Max.
12v dc
Reloadron
Joined Jan 15, 2015
5,720
any idea where i can buy these
No, since I haven't a clue as to your location? I would start with a Google of:
irrigation timer with real time clock
Programmable Logic Controller with real time clock
and also...
Smart Relay with real time clock
You may have to work from the digital outputs and configure a few relays to FWD and REV your motor. You also need to consider your motor's current draw in selecting additional components.
Ron
Bernard
Joined Aug 7, 2008
5,719
Is there just one selection / wk. or multiple selections ? How often do they change ?
How fine are the min. 1 min., 5 min., 15 min. ?
Is the 2 hr. on time fixed for all selected times ?
