Yehey! It's time for our Science Experiment!
I have some few questions before our experiment will happen, I guess next week.
We are going to taste a diluted hydrochloric acid. Is hydrochloric acid a scientific name for muriatic acid?
What do you think guys is the taste of hydrochloric acid? Is it safe? Or what?
Don't worry our Science teacher will be there at our lab together with us.
How to find the volume of an irregular shaped items?
It is like
1st, Record the volume of water.
2st, put the irregular shaped item on water in beaker.
3rd, minus the volume of water (only) by the new volume (the water volume plus the irregular shaped item)
4th, is that the answer already? We should put ^3, right? Like 3 cm^3
What do we call like that? Water displacement????
Can I use Hydrochloric acid as an alternative acid for Sulfuric acid for a Voltaic Battery? Will the Hydrochloric acid react If I put zinc strip, copper strip, and a bulb? What will happen?
Thanks so much.
It is like
Thanks so much.
