How to test each sensor ?
Djsarakar
Joined Jul 26, 2020
310
Hi
I have a sensor kit with a many of sensor. I want to understand each sensor's work, how they work without connecting to microcontroller. I would like to use broadboard and multimeter for testing
Can anyone help me understand working of above sensor
jpanhalt
Joined Jan 18, 2008
10,219
Apparently, this is the schematic:
Source:
"Explains" it.
If you look at a light with closed eyes and gently press on your eyelid you can see your pulse too. Sometimes, you don't even need to press the eyelid. What that simple sensor does is measure the change in transmitted light intensity with each pulse. Your index finger or thumb may be satisfactory sources, Your middle or ring finger are probably not so good. If you are young, try it on your big toe. ;)
Edit: The web between thumb and index or index and middle finger may also work. Experiment.
6,997
Hi
To gain an understanding of the sensor operation you need the circuit of the sensor. The sensor in the photo has an LED and a phototransistor. It sees changes in the light absorbtion as changes in the photo transistor conduction, which results in a changing voltage output.
6,997
Evidently my description was not what the TS wanted.
jpanhalt
Joined Jan 18, 2008
10,219
sensor kit https://aws.robu.in/wp-content/uploads/2017/07/Arduino-37-in-1-Sensors-Kit-1-1.pdf
I think microcontroller will have to be used to test this sensor.so far now I will postpone this plan and I will test other sensor in which microcontroller is not required
The sensor you show in your first post is not the same as on page 31 of that link. The sensor in your fist post probably doesn't need a microcontroller. Have you switched fields?
How are we supposed to give any reasonable answer to your question if neither you nor we have any idea which sensor you are using? Another mega thread in the making?
@MisterBill2
The link I provided (post#3) is the sensor and its schematic for the picture posted by the TS in post #1.
Djsarakar
Joined Jul 26, 2020
310
I do not have documents or user manual for all sensor. I thought that the given link might useful to understand the sensor, so I had posted that link
jpanhalt
Joined Jan 18, 2008
10,219
You have yet to say which sensor you are using. You show the picture of one and link to a different one that doesn't meet your specification of not using an MCU.
We can't possibly tell you how every sensor you might image works, but maybe that is where this thread is headed.
Edit: Emphasis added.
SamR
Joined Mar 19, 2019
2,558
To understand it, find and read the Product Data File. To test it, most of those modules are built solely to interface with a uC of some sort. So the only way to test it is to connect it to the uC and write a program to interface with it. Each of those modules is built around a particular chip with all of the chips necessary peripheral components. Locate the chip, read its component ID numbers, and find the PDF for that chip to understand how the chip itself works.
Djsarakar
Joined Jul 26, 2020
310
KY-009 RGB FULL COLOR LED SMD MODULE
This LED contains light emitting diodes. A red one, a green one and a blue one.
How to get all three colors without connecting to microcontroller. (I want to check on breadboard with multimeter)
bwilliams60
Joined Nov 18, 2012
1,341
I am going top guess you have bought the Arduino ELEGOO kit or something similar.
You first need to identify what is in the kit and I am sure there is paperwork available or online.
Once you have that start looking at datasheets for the component.
If you want, take Paul McWhorters trip through the Arduino which encompasses most of these components if that is the kit and he tells you what they all are and how to connect them to a breadboard and an Arduino if I remember correctly.
SamR
Joined Mar 19, 2019
2,558
It's common cathode so pin 1 to gnd. Each color needs a current limiting resistor ~220Ω and a potentiometer ~1kΩ. Supply each potentiometer with 5VDC. And have fun! By adjusting the pots to vary the strength of the individual RGB colors they mix to allow many different colors to be given off.
Look, search
and you shall find:
I remember a time I was working with somebody programming in Fortran for the FIRST time. The project took us about 9 months. I kept asking questions. He finally said "Look it up". No Internet back then, but the manuals for this system was a shelf about 4 feet long full of binders.
The FORTRAN manual, I think, was just one binder.
Now it's RTFM, but now you have to find it first.
I HATE the "no packing slip" mentality now. Aliexpress, for instance, one order number for 30 items and no packing slips, PO # or any identifying marks.
SamR
Joined Mar 19, 2019
2,558
Except the module is common cathode and he wanted to test it without using a uC. The TS needs to read the PDFs. All it takes is a little time googling.
SamR
Joined Mar 19, 2019
2,558
The really bad part is there are no real pdfs for these modules. The best you can hope for is a schematic with component values and hopefully the part number for any IC components.
