The only advantage I see in the 6 pin ones is the base lead for the transistor. I use 4 pin ones just because they take up less board space, plus the 4 pin ones, if you get the DIP style casing, you can plug 2 of them into an 8pin dip socket. (BTW, the part number I gave you is for surface mount, not through hole, but can still be easily soldered by hand....)BMrose,
Thanks for the lead. I see LTV-816Shas 4 pins only whihch is just fine. Will look nto ot's cost tomorrow.
BTW, do the 6 pin ones have any major advantage over 4?
